I have a hose bib that's leaking when turned off that I need to replace.
I used channelocks to hold the pipe in place and a wrench to try and turn the bib counterclockwise to remove it if it was threaded. Did not work.
Is there a way to know if its soldered on or threaded? If soldered, how much should it run me for a plumber to cut the pipe, attach threads to the pipe to put a new hose bib on and allow easy replacement for me in the future?
Picture attached. Thanks for any input.
