Removing Tub Spout
Discussion in 'Shower & Bathtub Forum & Blog' started by MissRancher, Aug 30, 2008.
  1. MissRancher
    MissRancher New Member
    Aug 30, 2008
    I'm trying to replace our tub spout but I can't figure out how to get it off. I thought I could just unscrew it, but either I'm wrong or something is stripped, because it just spins and spins and nothing happens. Am I supposed to do something other than spin it off? Now I'm paranoid that with all my spinning I've weakened the connection to the pipe and I'll have a leak inside the wall. Any advice? Thanks!
    [​IMG]
  2. jadnashua
    There are two types of spouts (generally) - those that screw on/off and those that push on. It appears yours is a push-on type. Somewhere, visible through that notch on the bottom, is a set screw that you have to loosen first. Then it will just pull off. You may have scored the pipe making it difficult to seal a new one, but you won't know until you get it off. The push on type use o-rings to make a seal, and the pipe must be smooth for them to work. Clean any burrs or you may slice the o-rings when you install the new one.
  4. MissRancher
    Aug 30, 2008
    Thanks for the response!
    I don't see a screw visible through the notch on the bottom. And when I turn the spout, the white plastic bit, and everything else which is inside the spout, turns as well. So if the screw is somewhere else inside there, I can't access it.
    I tried to immobilize the white plastic bit inside that notch so I could try and turn just the spout but not the inner bit, but I couldn't do that either.
    Any other ideas?
  5. MissRancher
    Aug 30, 2008
    Well with some creative use with a hacksaw, we found the screw and got the spout off. The copper pipe is indeed scored from the screw rubbing around it.
    Thanks for the help!
  6. Terry
    Aug 17, 2004
    [​IMG]
    The better diverter tub spout is made by Delta.
    There is a brass fitting that solders onto the copper stub.
    And then the spout threads onto that.
Similar Threads: Removing Spout
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Removing Difficult Tub Spout May 26, 2015
Shower & Bathtub Forum & Blog Removing Price Pfister Tub Spout Jun 27, 2008
Shower & Bathtub Forum & Blog Removing old Delta spout / diverter Sep 9, 2007
Shower & Bathtub Forum & Blog Removing tight bathtub spout Apr 14, 2007
