Pulsafeeder Chemical Feed Pump wiring
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Wellmate, Nov 11, 2010.
  1. Wellmate
    Wellmate New Member
    Nov 11, 2010
    Bonney Lake WA
    I am installing a pulsafeeder chemical solution pump (220v) in my well water supply line just infront of the pressure tank. I would like to install it so it operates when the well pump is running and filling the pressure tank. My question is......do i wire the pulsafeeder pump to the pump switch itself...or to the control box or???. I would like to know, where i need to cut the wires and splice it in...or if i just wire it to existing terminals. Thanks in advance
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Wire it in parallel with the well pump motor, assuming the chem. pump motor is also 220v. Depending on the current draw of the chem. pump you might need to resize wire or breakers or make other adjustments.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    You can wire it to the "load" side of the pressure switch, or tie it in with L1 and L2 in the control box.
Similar Threads: Pulsafeeder Chemical
Pumps and Tanks Well Forum & Blog. Water is life. removal of sediment through chemical injection Mar 6, 2012
