New Drain Set Up...does it look right?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bbillcee, Feb 25, 2007.
  1. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    I have a pic of a diagram of what i am going to install for a slop sink and laundry drain....can someone look it over and see if it looks correct!
    also if I added a 'Y' fitting directly off the vent to split the drain and used 2 traps is it ok to have a trap about 8 feet away from the the vent stack?
    [​IMG]
  2. Cass
    Cass Plumber
    Nov 12, 2005
  4. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    please see the updated photo
    the trap for the slop is within a foot of the vent
    i can't use that trap also for the laundry? i would have to use a separate drain and vent?
  5. Cass
    Cass Plumber
    Nov 12, 2005
    The washer needs its own trap and vent.
  6. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    excuse the ignorance but why would it not work?
    no gases would be able to come back into the hosue because of the existing trap? so what potentially would it hurt?
  7. Cass
    Cass Plumber
    Nov 12, 2005
    Each fixture has to have it's own trap and running traps are not allowed.
  8. Terry
    Aug 17, 2004
    Just wye off for the washer below the slop sink trap,
    Add a p-trap for the washer and either tie a vent back and revent at 42" above floor, or add an AAV on the trap arm for the washer.
    Most of these codes have been determined already by what does and what does not work.
    As licensed plumbers, we really don't feel inclined to "reinvent" the wheel,
    or to install plumbing that will be "turned down" by the inspectors,
    Or waste time and material installing stuff that will be turned down, or cause problems for the homeowner, and future homeowners.
    This sounds like a discussion that I would have with my youngest,
    A little like answering why rainbows have the colors placed the way they do, and why they have a round arc to them.
    Meanwhile, I'm just trying to locate the store I'm driving to.
    I may not be able to explain the rainbow, but there it is, for God and everyone else to see.
    A lot of the codes covers two things.
    Prevent traps from siphoning.
    Prevent smells from long untrapped sections of pipe, like in your drawing.
    And prevent cross contamination.
    Yeah, that's right, three things.
    But who am I kidding, there's a lot more than that.
    I will be going to Guatamala in March, and will get to see some really innovative plumbing like the stuff in your drawing.
    I'll just make sure not to drink their water.
    By the way Belieze City had the most horrible smell out in the bay as we boated out to the Cayes. I saw the most amazing collection of mistakes.
    The smells were horrible.
    When I was there, I told myself that I would try to put on the Internet, better ways for people to plumb. Central American is hooked up to the Internet, but they have no books or libraries.
    I asked them how they learned to plumb,
    The answer was,
    "I just look at the building next door, and copy it"
    Too bad for them, there was nothing done right in the first place.
  9. Terry
    Aug 17, 2004
    [​IMG]
    plumbing with vents
  10. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    1st problem...
    You cannot dump waste into a vent pipe...
    You have to run another waste...
    2nd - you cannot run 2" more than 3'6" from vent to P-Trap (at least here...)
    3rd - You cannot have a running trap as was pictured earlier
    If you can tap into the waste stack below the fixture the existing vent is venting, we can probably help you do this in a way that will work (and be legal)
  11. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
  12. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    thanx for a nice helpful post....this would be much work.....including busting out the concrete floor!
  13. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
  14. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
  15. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    by the way....is using 2" pipe for all this ok or should i go to 1 1/2"
    thanx
    where are u guys from anyway?
  16. Terry
    Aug 17, 2004
    You could just run your washer hose to the slop sink.
    A mop sink is also rated at three fixtures, same as the washer and has the 2" trap.
    I know a little about electrical, but not enough to give advice on it.
    Not that they listen, a friend of mine keeps blowing breakers on her 1100 over the range micro, it's wired to the lighting circuit.
    I always try to refer some good electricians that I know.
  17. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    yeah thats how i originally had it but i removed a giant 2 basin 1935 sink that was about 4 feet long with a slop sinkto the right of it.......plus i am tired of keeping a stocking over the hose and all that.
    i will try as u advised with the 'y' fitting with a trap for each and AAV for the washer.....seems like a good enough solution....
    thank u for the help
  18. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    I did the job.....2 slight problems....#1 the slop sinks fills with water when the laundry drains......
    #2 the ever so slight drip at the nipple where it connects to the cast iron
    when i say slip drip i mean one drip every minute when laundry is draining ....any trick i can do with that???
    please tell me if u see anything wrong....this is the 1st time i have done this
    [​IMG]
    [​IMG]
  19. Terry
    Aug 17, 2004
    Now that I have pictures, I can see better.
    That studor vent (AAV) will help with the washer line.
    Good job with that. I see that you used 2", which is code for that.
    Darn, it's looks pretty good for your first try.
    What I don't like is two fixtures on the one trap arm.
    If you had cut the cast iron, it would have been pretty easy to have two tees.
    The lower one could have been for the washer, and the upper one for the laundry tray.
    That way, the upper laundry tray would have the 2" vent going up,
    and the lower tee would have supplied the washer that uses the studor vent.
    [​IMG]
    I know that sounds major, but cutting cast is not really that hard.
    I sometimes use a 618 sawzall blade, but most often I use a snap cutter for the cast. Snap cutters can be rented.
    If you were to ask, will this work the way it is?
    I would guess that it would. What you are worried about is whether the trap on the tub siphons or not, that should be easy to see by looking down that drain.
    By running the washer water past the tub drain, without the seperation of a vent, that is the risk.
    I don't think that is the problem with the tub filling though. You may have a blocked line that needs snaking.
    Plumbing tips:
    Plastic pipe can be supported every four feet, if that's a concrete wall, you may need a rotohammer for that.
    The Laundry tub could have been trapped with a 1.5" p-trap, but the 2" will work nice too.
  20. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    thanx terry ...i gave the line a quick snake ...i think u may be right.....i think there is a slight blockage....i will give it a better snake tomarrow....
    these parts were very inexpensive and now that i got a taste i might do it over the way u said
    where would u cut the cast on the lower half?
    right below the collar where it connects to the part where i connected to?
    and what do u use to connect back? those rubber boots with the screwdriver clamps???
    and what pipe gets put back? PVC or cast?
  21. bbillcee
    bbillcee Member
    Feb 25, 2007
    New York
    also here is a pic of the cast iron lines.....u may see a easy way to do something different
    looking at it again it looks quite simple to just pull that piece out
    the top portion of the pipe i connected too turns into galvanized[​IMG]
Similar Threads: Drain Updoes
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Today at 9:32 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Yesterday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Yesterday at 11:21 AM
Plumbing Forum, Professional & DIY Advice How to get hard plastic piece out of the drain? Yesterday at 9:54 AM
Plumbing Forum, Professional & DIY Advice HELP PLS - Drainage for Filtration and Softener System Thursday at 9:19 AM
