Need washer & sink plumbing setup advice.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by AnthonyC, Jul 1, 2013.
  1. AnthonyC
    AnthonyC New Member
    Jul 1, 2013
    Honolulu
    I have been searching high and low for info on how to setup plumbing for a washer and sink and finally found this drawing on this site. The diagram is close to what I need except my sink is on the left side and the washer is on the right.
    Base on this diagram, can I run the sink drain below the washer drain or run the washer drain directly to the vent and add a new vent above 42" to the sink drain instead? Reason for asking is to avoid cutting too many holes on the wall stubs.
    Thanks
  2. Terry
    Aug 17, 2004
    [​IMG]
    More like this?
  4. AnthonyC
    AnthonyC New Member
    Jul 1, 2013
    Honolulu
    Thanks! That's perfect. --
    Oops spoke to soon. Here's the issue I having.
    The vent line is about 7 feet to the right side of where my sink and washer are. From your picture, I can't get the sink drain line to the sink inside the 4" wall. I can run the drain line outside of the wall but was hoping to hide all the pipes.
    Issue -
    Will this work?
  5. John28
    John28 Member
    Mar 17, 2013
    PA
    Not sure if you'd should tie the sink drain in below the standpipe? Probably above?
  6. John28
    John28 Member
    Mar 17, 2013
    PA
    What was the outcome?
Similar Threads: Need washer
Plumbing Forum, Professional & DIY Advice Washer P- trap needed Jan 2, 2017
Plumbing Forum, Professional & DIY Advice Need help on planning washer & utility sink setup Oct 13, 2016
Plumbing Forum, Professional & DIY Advice Problems with Laundry Washer. Need help. May 26, 2015
Plumbing Forum, Professional & DIY Advice Need adivce on replacing washer shutoff valves Feb 5, 2014
Plumbing Forum, Professional & DIY Advice Need to Connect a Countertop Dishwasher to a Nonconventional Faucet (Moen Renzo) Jan 15, 2014
