multi supply line valve shut off doesn't!
Discussion in 'Remodel Forum & Blog' started by treasure37, Jan 27, 2006.
  1. treasure37
    treasure37 New Member
    Jan 27, 2006
    Hi,
    I am attempting to replace my countertop and kitchen sink tonight. Under my sink the single hot water valve has 2 outlets on it, 1 to the faucet and 1 to the dishwasher. When I tried to turn off the water it began to leak. I tightened all the connections and tried to turn it off again but the water stays on full to the faucet no matter which way the valve handle is turned.
    Could this be a defective valve? A buildup? Installed incorrectly? The valve is one of the standard chrome ones and I believe it's about 10 years old and we have never had to turn ir off before.
    I know I can cut the main water. Remove the valve and replace it with two valves sweated in series to give each applaince its own. But I had hoped to get this project rolling tonight.
    Any ideas would be appreciated!
    Thanks,
    Sam
  2. Terry
    Aug 17, 2004
    Welcome to plumbing.
    That's why we try to have everything on the truck, "In case it doesn't work".
    Most shutoffs under the sink will stop if they are threaded in clockwise.
    That doesn't mean they all still work after a number of years.
    Any hardware store should have replacements.
  4. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    leak
    Might be leaking at the packing on the stem.
    Shut the main valve off and take off the pressure. Put a pan under that shut off and partially open it. Unscrew the hex cap under the handle and grease the stem at the packing gland. Check to see if the washer on the end of the stem is good and then put it back together. Screw the stem back in and then tighten the hex packing gland. That should take care of the drip under the handle.....
  5. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    These valves fail very often. The fact that it supplies both fixtures is not the problem. Is it sweated on? If you are lucky, it is a compression fitting which can easily be replaced. One way or another, replace the valve now while you have easy access to it.
  6. dubldare
    dubldare Plumber/Gasfitter
    Sep 14, 2005
    Plumber/Gasfitter
    MN/ND
    Dual-outlet stops are not legal where I'm from.
    We require independent shut-off of each fixture/appliance.
Similar Threads: multi supply
Remodel Forum & Blog Bathroom ventilation - multiple fans to one 4" eave vent duct Jan 20, 2015
Remodel Forum & Blog Multi Zone HVAC Jun 26, 2006
Remodel Forum & Blog venting multiple fixtures... Jun 10, 2006
Remodel Forum & Blog Old Soft Copper Water Supply Pipe Feb 28, 2017
Remodel Forum & Blog Dishwasher and Icemaker Supply Lines Question Dec 14, 2016
