I would make your connection to whichever hub makes for the easiest work, best angle to insert that donut. In the sink compartment I like to install my cleanouts above the sink connection and definitely not in the crawlspace. Depending on your sink requirements, I generally try to install my stub out behind one of the sink drain locations and typically pointed just off center of a disposer. That way I bring my continuous wastes together at one of the sink bays and that leaves most of the sink cabinet open.
That's just the way it's piped now. Is it okay to remove that last wye in the crawlspace and just do a 45? Then it could be snaked from the stub out?
This is the way my under sink looks now. I'm really struggling with how to clean it up. The stub out is to the far right of the cabinet. I feel like this would be a lot cleaner if I moved the disposal to the other sink. That would allow me to put the trap under the right sink and just pipe the disposal straight over like the way preferred here. It seems like most people prefer it in the smaller bowl, but that doesn't really matter to me.
I want to make the stub out lower which will hopefully allow me to use only one trap.
A big problem I'm having right now is how crowded the space behind/between the two sink bowls is. I have a touchless faucet with a giant valve brick up in there. Sometimes the sprayer hose gets stuck. I don't even have enough room to get the weight on the hose.
(When I do this, I'll also be replacing the inlet valves and wiring the disposal on an outlet and cord to eliminate exposed Romex.)
Sorry, that got longer than expected!
For the IPC, in use in North Carolina, the red kitchen sink fixture drain could be either 1.5" or 2". But 2" is generally preferred.
Cheers, Wayne
Thanks. I will go w/ 2" unless I run into something unexpected.
