Is there a definitive way to tell if it's a leak?That may be a leak. Sometimes cast iron does develop leaks like that.
Maybe let some other plumbers here give their opinion too. Where I'm at, we don't let things get too old. The street I grew up on with 1952 homes have pretty much all been replaced. Though if I head into Seattle, there are homes from 1910 still there. I'm not sure if my grandfathers home from 1890 is still there or not.
My house was built in 1958. But this branch goes to the kitchen sink, so I'm assuming it's had a lot of Draino run through it over the years.Maybe let some other plumbers here give their opinion too. Where I'm at, we don't let things get too old. The street I grew up on with 1952 homes have pretty much all been replaced. Though if I head into Seattle, there are homes from 1910 still there. I'm not sure if my grandfathers home from 1890 is still there or not.
That would be good if you can do it.Maybe the best solution is to bite the bullet and replace the entire branch from the main drain to the kitchen sink riser. Then there would be no horizontal galvanized pipe left in the house.
The drum trap isn't in use anymore thankfully. The standpipe is buried in the wall behind the kitchen cabinets. I assume someone plugged it up since I don't smell sewer gases in the house.Without any doubt replace it all including the Drum trap as a lot of codes outlawed them
How big of a project is replacing the part of the sink drain that goes up in the wall?When I'm looking at a remodel project to estimate the cost, I look at the age of when the home was built. There was some eras where imported cast iron was used and its typically trash. If there are that many pinhole leaks in the cast iron and that kitchen drain is that clogged up, I would recommend replacement.
It is relative. You have to open the wall. Good chance the pipe above the sanitary tee is galvanized vs cast. So you cut thru the galvanized, and try not to cut thru the wall behind. Then you use a shielded coupling to transition from the galvanized vent to the new PVC below.How big of a project is replacing the part of the sink drain that goes up in the wall?
Yeah, a few months after we moved in, I had to call a plumber to unclog the drain. They were here for like an hour and a half with a power auger working on it. Apparently they were having trouble getting the snake to go the right way.When I'm looking at a remodel project to estimate the cost, I look at the age of when the home was built. There was some eras where imported cast iron was used and its typically trash. If there are that many pinhole leaks in the cast iron and that kitchen drain is that clogged up, I would recommend replacement.
Is all I have to do enlarge that opening enough that I can cut out the fitting and get a Fernco sleeve on the vent pipe?
I went down in the crawl and took some more photos.The minimum I would recommend is to open the back of the cabinet.. A big hole is as easy to patch as a small one.. Just leave enough on the perimeter to screw on a new plywood along the back.. Cut above the drain on the vent enough to band onto.. then remove what you need to get into the crawler and to where you find clear pipe.. probably at the stack. Getting the bit out where it goes through the floor may be tough so you may need to drill or cut a new hole through the plate. Just depends on what you find.
Diablo makes some expensive blades for a reciprocating saw that cut through cast iron. I prefer to use an angle grinder but they're more dangerous and make a lot of dust.. So goggles with a Full Face Shield are a must along with a respirator.
