Is this pressure relief valve working properly?
Waynef
Georgia
When my pump starts, it squeals, then a small amount of water spews from this valve. What kind of problem am I having? Just took cover off of well, looks like it has been doing this for awhile.
DonL
Houston, TX
Hello Wayne,
If that is a heating wire on that valve, then I would remove it.
It should not be coiled around the valve. maybe 1 turn only, or the wire could overheat.
The wire looks like it has been very hot.
Have a Great Day.
DonL.
P.S. The valve could have been damaged.
Ballvalve
northfork, california
As mentioned in your other thread, that whole mess is due for some upgrade to code, and here I agree with code. Conduit, cover, new valve, etc.
Your well tank might be waterlogged causing a pressure spike, or that sad valve is not set for the correct pressure.
At least fix the wires and get that thing under a dog house.
Waynef
Georgia
I finally got around to replacing the pressure relief valve, but it continues to spurt water when the pump shuts off. Is there some adjustment I can make to the pressure switch? Maybe make it shut off a little sooner?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Most of them you can take the cap off and tighten down on the adjustment screw to increase the pressure setting. But the fact that it happens at shutoff, makes me think you have a water hammer problem from two many or a bad check valve.
