Is this pressure relief valve working properly?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Waynef, May 11, 2011.
  1. Waynef
    Waynef New Member
    May 9, 2011
    Georgia
    When my pump starts, it squeals, then a small amount of water spews from this valve. What kind of problem am I having? Just took cover off of well, looks like it has been doing this for awhile.
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Hello Wayne,
    If that is a heating wire on that valve, then I would remove it.
    It should not be coiled around the valve. maybe 1 turn only, or the wire could overheat.
    The wire looks like it has been very hot.
    Have a Great Day.
    DonL.
    P.S. The valve could have been damaged.
  4. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Relief Valves shouldn't leak until a certain pressure. It's a relief valve, it does nothing unless excessive pressure is reached.
  5. Terry
    Aug 17, 2004
    The spring wear out over time.
    You might consider replacing it.
  6. ballvalve
    Dec 28, 2009
    northfork, california
    As mentioned in your other thread, that whole mess is due for some upgrade to code, and here I agree with code. Conduit, cover, new valve, etc.
    Your well tank might be waterlogged causing a pressure spike, or that sad valve is not set for the correct pressure.
    At least fix the wires and get that thing under a dog house.
  7. Waynef
    Waynef New Member
    May 9, 2011
    Georgia
    I finally got around to replacing the pressure relief valve, but it continues to spurt water when the pump shuts off. Is there some adjustment I can make to the pressure switch? Maybe make it shut off a little sooner?
  8. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Most of them you can take the cap off and tighten down on the adjustment screw to increase the pressure setting. But the fact that it happens at shutoff, makes me think you have a water hammer problem from two many or a bad check valve.
Similar Threads: pressure relief
Pumps and Tanks Well Forum & Blog. Water is life. Well head pressure relief valve Feb 6, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Relief Valve Jul 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Lake pump pressure relief valve Jul 16, 2015
Pumps and Tanks Well Forum & Blog. Water is life. setting bladder tank pressure; selecting pressure relief valve Jul 5, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Under water pressure relief valve Jan 3, 2015
