In Wall Horizontal Pipe Runs
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jasonal119, Jan 24, 2010.
  1. jasonal119
    jasonal119 New Member
    Jan 17, 2010
    OFallon, MO
    I am in the process of finishing my basement and have a strange question. When you are running pipe horizontally within the walls (notched or through holes) which pipe runs above the other? Is the hot pipe on the top or the bottom?
    Also another (similar question)... in this basement I have an existing stack which was installed during construction for the half bathroom. The builder placed a saniary tee at the height for a sink drain and then capped it off. This stack sits between the bathroom and where a wet bar will be. I want to use that stack (2" stack w/ 1 1/2" stub) to drain both of the sinks. Can I run the pipes between the two sinks with another tee in the middle and connect the combined waste into the existing san tee? The sinks would both be in 1 1/2" PVC.
    Thanks for the help!
    Jason
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    There isn't any code that says which water pipe should be on top or the bottom. Good plumbing practice is to run both pipes as to not cross them. In other words, where ever possible, do not cross one pipe in front of the other.
    Your second question is =no
    Each fixture should be individually vented and separately trapped
  4. Terry
    Aug 17, 2004
    Most plumbers run hot high and cold low.
    It's not code, but it's common.
  5. jasonal119
    Jan 17, 2010
    OFallon, MO
    Thank you all for your help... Is there a "standard" for the height of the pipes in the wall? (The actual runs, not the connections for the fixtures which do have a typical height)
    Jason
  6. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    Shortest route possible.
    You're over thinking this.
  7. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    If you go with pex you can just throw it any witch way and no one will care ;)
  8. Lightwave
    Lightwave New Member
    Aug 20, 2007
    Vancouver, BC
    Don't place them 14" from the floor unless you're sure you're never going to put an electrical outlet in the wall.
    Don't place them 48" from the floor unless you're sure you're never going to put a light switch in the wall.
    Keep hot and cold pipes far enough apart that they can be insulated separately.
    Insulate all supply pipes that run above wiring or electrical boxes.
    Avoid running pipes in outside walls above frost depth unless you have no other option.
  9. hj
    IN the "old days" when piping was exposed, we ran the cold on top so that if someone leaned on them they would not get burned by the hot water pipe. WHat you want to do is possible, but the real factor is HOW you do it. That would determine whether it was correct or not.
  10. Terry
    Aug 17, 2004
    Pipes not in walls?
    Okay, was that before they moved toilets inside?
    Okay, I guess when I go into Seattle and see the old galvanzed pipes hanging in the basements you would worry about people leaning on the pipes.
    I started off when copper was in vogue.
    And we drilled studs and nail plated.
    I was glad I didn't have to thread pipe all day, though I did do a bit of gas piping.
    If I'm picket fencing the pipes, I set a 2x4 on the bottom stud with the 3.5" high side up and mark the studs.
    This way I could just throw a tee in for the water closet. (toilet)
    I then mark the top holes so it clears the lav stub out.
    But really, anywhere in the wall will work.
Similar Threads: Wall Horizontal
Plumbing Forum, Professional & DIY Advice Wall hung toilet and horizontal waste pipe Jan 13, 2015
Plumbing Forum, Professional & DIY Advice Hi may I run an horizontal soil pipe in the middle of the basent wall? Dec 3, 2014
Plumbing Forum, Professional & DIY Advice Main stack & offset walls: Run Horizontal? Jul 13, 2010
Plumbing Forum, Professional & DIY Advice Venting question on a double lav on outside wall. Tuesday at 9:13 AM
Plumbing Forum, Professional & DIY Advice Purging In-Wall SunRad Radiator Mar 14, 2017
