Hot water in toilet
Discussion in 'Toilet Forum discussions' started by mrhans1, Jun 8, 2005.
  1. mrhans1
    mrhans1 New Member
    Jun 8, 2005
    I maintain an eighteen floor office high rise building and I've run into a new challenge I need help with. Hot water is in the toilets and sinks on the 14th floor. Now I have hot water in all the cold water outlets on the 18th floor. The floors have seperate water heaters,individual single handled sinks and flush valves. It shows up in the mornings until the cold water runs or flushed enough times, then the water is cool again. Has anyone seen this before. Help!
  2. Terry
    Aug 17, 2004
    It happens when there is a temperary shutoff on a shower head.
    The homeowner shuts the valve on the shower head, but leaves the shower faucet on.
    The hot crosses through the valve and into the cold side.
    The fix is to educate them to turn "off" the faucets for the showers, not just for the shower head.
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    It probably is due to thermal expansion of hot water from the water heaters into the cold supply lines.
    Do these water heaters have expansion tanks on them?
  5. mrhans1
    mrhans1 New Member
    Jun 8, 2005
    Hot Toilet reply
    No expansion tanks. They are 17 gal. state water heaters. After reading this I went and looked at the pipes and I do not see a check valve or a flow back preventor on the cold water line before the water heater.
Similar Threads: water toilet
Toilet Forum discussions Toilet Water Gets Gone Feb 1, 2017
Toilet Forum discussions Better Toilet for Hard Water/Iron Conditions? Jan 30, 2017
Toilet Forum discussions Toilet water supply has been off a while...try to turn back on now and get a horrible loud noise... Jan 18, 2017
Toilet Forum discussions Toilet bowl slowly leaks water Dec 15, 2016
Toilet Forum discussions How toilets work - holding the handle down for more water Nov 14, 2016
