Filter+Regulator Before or After valve?
Flapper
California
(For Drip systems) I've always seen the filter and regulator after the valve.
It is recommended to have a filter before the valve.
So I thought, why not put the filter + regulator unit before the valve?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
It should still work, but the regulator will only let the electric valve have 10 PSI or so, and it might not have enough pressure to keep the valve closed.
Flapper
California
The regulator regulates to 30 PSI. Should be enough.
So it's just down to whether the filter + regulator is designed for constant pressure or not.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
The regulator is what maintains the pressure at a constant 30. With the regulator last in line you will have 30 PSI to the drip. If you put the filter and/or the valve after the regulator, the friction loss from these items will decrease the 30 PSI from the regulator to the drip.
