Most efficient type check valve for separating non filtered water
bikeboy
Toms river New Jersey
I'm installing a basic carbon water filter to filter chlorine from a city water supply. I've tee'd a line to all outside faucets ahead of the filter tank on the supply before entering line side of filter tank to not filter outside water. I'm assuming i'll have to install a check valve of sort to stop backflow from filter tank. I'm assuming a flapper type would be more efficient than a spring unit for better flow but may be orientation pedicular (only horizontally) operable. Don't know about a ball type. I've found a brass flapper type w/a silicon seal on Amazon.
Please reply if can help;
Thank You...
I don't remember anybody suggesting a flapper type check valve for supply lines. I would go spring-loaded.
Bannerman
Ontario, Canada
Is your plumbing system equipped with a thermal expansion tank? If so where is it located?
A check valve located between the water heater inlet and the expansion tank, will isolate the expansion tank from the source of expansion.
If there is no source of water pressure after the carbon system, I don't see much benefit in utilizing a check valve. Without a source of pressure (ex; pressure tank, thermal expansion tank, additional water supply) after the carbon system, there will be little if any back pressure or backflow through the carbon system.
bikeboy
I have two water heaters opposite sides of house. Closest unit to the in water supply has a WH and has a exp. tank just above the inlet supply to that WH. The in main water supply is located about 20 ft from that WH. Please explain.
Thank You...
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
A properly precharged expansion tank should seldom be a source of stored volume since the precharge would be the same as static. The stored volume would only increase when water is being heated at a time of no water use.
The small amount of reverse flow through the carbon filter should not be enough to unseat the media pack so the installation of a check valve is optional. Either a swing or spring type would work and the approx. 2 PSI required to open a spring type would not be noticeable unless the static pressure is poor to begin with.
bikeboy
Thank You w/ reply;
It may not upset the media in tank, but would there be a need for a check valve on the input to stop filtered water to being drawn to the outside faucets ? Most spring check valves I've bought were of high cracking pressure, which is why I've considered a horizontal mount swing type.
bikeboy
found a shark bite check valve @ local Home Depot ; probably a spring type; and has very easy cracking pressure that should be able to be mounted any direction and easily removed.
