Exposed rotor head pictures
Discussion in 'Irrigation / Sprinkler Forum' started by vaman, Jun 1, 2010.
  1. vaman
    vaman New Member
    Jul 15, 2009
    NJ
    Here are two pictures that better explain my situation with the exposed rotor head. One shows the exposed head and the other shows the supply line. You experts toss around all kinds of terms about the supply line which I don't understand so I thought the picture would best explain the situation.I replaced the entire rotor head unit with the same model as the original and did nothing to the supply line. It is lying horizontal in the ground. Only thing I can think to do is cut the supply line and add some extra so I can bury it deeper.Ideas are appreciated.
  2. BRD
    BRD New Member
    Jun 22, 2009
    irrigation contractor
    northeast
    First thing to do is is to cap the fitting so dirt does not enter. The fitting appears to be connected to swing pipe which is very flexable. Dig back and expose the swing pipe for about 12" or so. this will give you room to lower the head a couple of inches. If the swing pipe is short where you do not have much flexability, you may have to dig back to the line that feeds it and lower it a bit. Put teflon tape on the fitting before replacing the head.
  4. hj
    Black pipe is unusual so what you can do depends on whether the pipe is rigid or flexible, and how you could connect any revisions to it, since black pipes can seldom be glued.
  5. vaman
    vaman New Member
    Jul 15, 2009
    NJ
    Did as you suggested and it worked! Thanks
Similar Threads: Exposed rotor
Irrigation / Sprinkler Forum Rotor Heads Exposed Apr 13, 2010
Irrigation / Sprinkler Forum Submersible pump practical for large yards with Rotors Apr 25, 2011
Irrigation / Sprinkler Forum Old, old Toro rotor Oct 2, 2010
Irrigation / Sprinkler Forum Weathermatic T3 Rotor Arc Won't Adjust Jul 6, 2010
Irrigation / Sprinkler Forum Hunter rotor head adjustment screw Jun 17, 2010
