Drake I vs. Drake II
Discussion in 'Toilet Forum discussions' started by Beski, Jan 4, 2013.
  1. Beski
    Beski New Member
    Jun 29, 2012
    New Jersey
    I have done a Search, but still don't have the exact info I need !!
    We had the Drake I at our former house and were Very Happy, so I don't want to go "Down" in Flush Quality. I now need 3 New Toto Toilets and I am still trying to figure out which of these Drakes has the "Best Flush" and if I should now consider the Drake II?
    So if the Price on the Drake I was the SAME as the Drake II, and I didn't care about 1.6 GPF vs. 1.28 GPF, which will provide the Best Flush ?
    From the posts I read, I have concluded that there is NO "Noticeable" DIFFERENCE between the Drake I and Drake II and I just want to be sure this is True ?
    In most cases the Newer Model is "New & Improved" so is that the case with the Drake II ?
    Thanks & Happy New Year !!
    Tom
  2. stephenk
    stephenk Member
    Nov 18, 2012
    Plains
    The regular Drake has a 1,000g map rating, while the Drake II has an 800g map rating. The Drake II uses a different bowl wash system, too. The II has the Double Cyclone flushing system. It uses two large vents that release water, instead of a series of holes under the rim like most standard toilets use.
    This video shows a different model, but it has the same Double Cyclone flushing system used in the Drake II.
    How happy were you with the bowl wash on the regular Drake?
    I've had the Drake II for about a month, and I haven't been super satisfied with the bowl wash compared to some other low-flow toilets I've used. But, the other ones I've used were 1.6 gpf units. I don't know how the bowl wash on the Drake II compares to some other 1.28 gpf toilets. It does flush very well, though.
  4. Beski
    Beski New Member
    Jun 29, 2012
    New Jersey
    Thanks for the Fast Reply !!
    We have been "Plunging" 5 out of 7 Days for the past few months, so at this point "Flush" has become Very Important !!
  5. Terry
    Aug 17, 2004
    The Drake II has been a good bowl for me. The Vespin II uses the same tank, and virtually the same bowl but skirted.
    If you need more rinse, just hold the handle down instead of doing the quick release.
    Advantage of the Drake II would be
    Sanagloss
    Tall bowl
    No rim to clean under
  6. Beski
    Beski New Member
    Jun 29, 2012
    New Jersey
    Thanks Terry !!
    I guess those are some good advantages !! Just called the local Supply House and they have 25 in stock, so probably buying my Christmas Presents tomorrow !!
    Tom
  7. stephenk
    stephenk Member
    Nov 18, 2012
    Plains
    My Drake II does have a rim you have to clean under, but by the design part of it is easier to clean than the rim on a regular toilet.
    If I had to do it over again I still might choose the Drake II over the regular Drake. The Double Cyclone is a unique design that I like. And, my Drake II is made in the USA, which is worth a price premium to me.
    I just poked around on the Toto website. You can get Sanagloss and ADA height on the regular Drake, but it looks like you can't get both ADA height and Sanagloss together unless you step up to the Drake II.
Similar Threads: Drake Drake
Toilet Forum discussions Can you help to identify this Toto Draket toilet part? Yesterday at 9:06 PM
Toilet Forum discussions Install help for Toto Drake with closet flange below floor Jan 28, 2017
Toilet Forum discussions Help decided Drake ver1 Vs Ultramax 2 Jan 22, 2017
Toilet Forum discussions My Toto Drake, Flush Handle & Flapper Issue Jan 14, 2017
Toilet Forum discussions Toto Eco Drake vs Kohler Wellworth vs AS Champion Pro Jan 1, 2017
