discodizan
Tried installing a new Kohler Proflex K-1142-R-0 bath tub today and ran into an issue with the drain hole in the tub. The thickness of the acrylic material where the drain hole was drilled varies significantly from front to back of the hole. So when you try installing the drain shoe, the gasket get pulled tight on one side, but doesn't seal up tight on the other. I have tried two different drain kits with the same results - leaks. Any ideas? Additional or thicker gasket material? Try "shaving" down the thick side of the opening to get it equal?
Thanks,
Thanks,
