I'm resetting a toilet in one of my bathrooms that has begun to smell - I figured the problem was the wax seal. When I got the toilet off though, I realized that the existing flange was very old and not mounted to the floor at all. It is a cast iron pipe and flange. I purchased a new flange with a rubberized gasket that is supposed to form a seal around the outside of the 4" drain pipe.
My problem is that my entire floor and subfloor is cut so far away that I have nothing to mount the flange to. I can put it on top of the drain pipe, but can't secure it to the floor.
I discovered because I had already put on a new wax seal and placed the toilet when I realized I couldn't get it to stop wobbling. I kept on tightening the closet bolts, but finally realized that when I was tightening the bolts, I was just pulling the flange up off the drain pipe.
Without mounting the flange to the floor, how is it possible to get a good tight seal and a non-wobbling toilet? I looked a bit for something that would go over the flange and extend enough on the sides to allow me to mount it to the floor, but couldn't find anything. Any ideas?
