G'day. In installing a new toilet I accidentally popped the closet flange off of the 3" copper riser. I replaced the flange with a multi-purpose PVC replacement flange that slipped into the riser. (the replacement riser was the type that had a 6" tail-piece with a gasket on the outside of it).
I have an issue in that the sub-floor doesn't go underneith the flange tight to the riser. Rather it was cut around the peremeter of the old flange, therefore, i do not have any thing to fasten the replacement flange to.
So now I have a toilet that is essentially held in place by gravity. It will wobble and can twist around on its axis.
Can someone please guide me on how to remedy this? My thought was to use thin-set mortar to set the toilet in place. will this work? Should I use a different type of mortar or a different solution?
Thanks.
Thanks.
