Southpaw134
is there such a thing as over sloping (too extreme of an angle) an outdoor 3" sewerline?
I assume there isn't, I assume there are some sewer lines that run vertical..., but assuming is, an, umm...big assumption.
Also, if I have a vertical line that I need to connect to a horizontal line is there a minimum or mximum angle of connection between the two (i.e., 45 or 90 degrees)?
Thanks in advance.
Thanks in advance.
