egonline
Hello all,
I am a DIYer and I am redoing my primary bathroom, and I'm looking for advice/review of my plumbing plan to ensure I'm interpreting the code correctly.
I have a double lavatory (with a single p trap and drain), a water closet, and a shower drain in this bathroom group. Here is a sketch of my current plan:
I'm fairly certain this is wet vented properly (please correct me if I'm wrong), but my main concern is the orientation of the wye fittings. Should the LAV drain/wet vent connect (wye #2) to the main drain line horizontally, or should it be rolled up to ~45 degrees? same with the shower drain connection (wye #1) - horizontal or rolled up? This is all in a crawl space, and vertical height isn't a large concern.
I feel like I've seen conflicting information on this.
For example, this brochure referencing IPC 2018 shows a combination vent system very similar to this, with the LAV sink coming in from above, not horizontally (figure 3 below).
However the latest version of the Florida plumbing code that I can find (2020 IPC amended), it seems to call out that it should connect horizontally.
Any advice/insight into this distinction would be very helpful! Thanks in advance - I know I'm not a plumber, just a DIYer doing his best.
Evan
Evan
