Rear outlet toilets
Mad Plumber
Mad Skills
For residential use, there are a few options for rear outlets.
These all use a tank to store the water for a flush, some are mounted on the bowl, and some are in the wall.
These can be fed by a 1/2" pipe and 3/8" supply.
If you are looking for floor mounted rear outlets,
the are made by
Gerber Ultraflush 21310
Amerian Standard Yorkville
Kohler
Briggs
Caroma Wallvit
Glenwall
If you are looking for wall hung rear outlet toilets,
American Standard Glenwall
Caroma Wallvit
Duravit
Porcher
Toto CT708
Commerical bowls use a 1" flushometer valve and don't work well with the small residential sized piping.
Most of the time, these are on systems with 2" meters and 2" mains or larger and will have 1" branches for the supply.
If your home has a 3/4" or 1" meter, don't even think about it.
Toto
American Standard
Gerber
Kohler
Eljer
Crane
Back
