OK, I have been searching far and wide for help on what I believe is a Delta 1300 or 1400 series valve and can't find the answer.
The valve I have is the Delta Classic single handle acrylic knob. It is NOT one of those that works by turning the knob from an off position (all the way clockwise) to on (by turning counterclockwise), nor is it one that pulls out to turn the water on, rather it adjusts the volume control by moving the knob up and down. The temperature control is accomplished by turning the knob left and right.
I believe the valve is circa mid 1990's (when the building was remodeled), and have not been able to find a similar cartridge, or even any references to this style Delta valve. All the current Delta cartridges for the universal / multichoice do not appear to function like my current cartridge. I would like to purchase a new cartridge that pulls out to adjust the volume control.
So, my question is this:
How do the currently available Delta Monitor cartridges operate? (Although I do understand how the 1700 series works.) Do they pull out to turn the water on, or do they turn counterclockwise to turn the water on? Are there any Delta cartridges that work for the multichoice that do operate this way?
A few additional keywords to help those in the future...
rough valve
RP46074
RP19804
T13022
T13122
T13222
T13422
rough valve
RP46074
RP19804
T13022
T13122
T13222
T13422
