Scottp999
Hi, looking to install one or two big blue filters at my mother in laws house before a water softener. One to remove sediment, and one maybe for carbon block to keep some chlorine off the resin.
The issue is she has no basement drain and the sewer is elevated 7' above the basement floor. She is roughed in for a basement bathroom, which has drainage and venting to a rough in pit for a sewage ejection system (future install). The utility area has the main waterline coming into a pex based home run type distribution for the house, and a tankless water heater. Even if she had an issue with the tankless water heater, there is no where for the water to drain now. The back of the house is walkout level. Should she install the sewage ejection pump now, and maybe have a floor drain put into that utility area that runs to the sewage ejection pit? Then there could be drain pans under the future big blue housings and water heater that lead to that drain?
Thanks for any thoughts.
