Condensate drain must not go directly into a plumbing system drain without an acid neutralizer kit.
https://www.supplyhouse.com/Axiom-N...iIzMQAAhrLLGhvnx-F5QbnxI2Qh1SwgQaAkEIEALw_wcB
If that is CSST, and depending on your model BTU rating, if over 10' of CSST then you may not have proper gas supply from 3/4" CSST. 3/4" CSST does not have equal capacity to 3/4" steel pipe.
Too bad you won't have a warranty: Takagi states: "8Page• Installation and service must be performed by a qualified installer (for example, a licensed plumber or gas fitter), otherwise the warranty will be void.• The installer (licensed professional) is responsible for the correct installation of the water heater and for compliance with all national, state/provincial, and local codes.• The manufacturer does not recommend installing the water heater in a pit "
As long as you didnt use brass pex fittings for condensate your good
Doesn't play nice with copper, galvanized, or cast iron either.Is this because the acidic water doesn't play nice with brass? Corrosion issues? Thanks for your insights!
If your drain is cast iron you need a neutralizer unless after a few years you want to pay to have the line replaced.Neutralizer is not required in my jurisdiction. We can actually drain these just about anywhere here.
I'm not worried about warranty when I could replace the machine 4 times before paying someone else to install one for me. Call me crazy...
This unit is the 160,000 BTU/hr model. The CSST run is 8' end-to-end. Furthermore, my digital manometer indicated .1 "WC of pressure drop with all gas appliances running at max versus all turned off, so I take that to mean the supply piping is sufficient. Would you agree?
I really appreciate your comments and thanks for taking the time!!
Thanks for your input. It seems there is ecological reason to do so as well, so it will make the hippies happy!! Got to like that! Reach4 mentioned the corrosion issues, so its certainly something more serious than I would expect. I like the idea of not paying $50 for some plastic and limestone tho! I am glad Reach4 mentioned it before I purchased the one in breplumb's link!If your drain is cast iron you need a neutralizer unless after a few years you want to pay to have the line replaced.
Could also take a five gallon plastic bucket with lid filled with chat and a bulkhead fitting mounted in side up at top of chat line. Condensate line through the top bulkhead fitting hose to drain.Thanks for your input. It seems there is ecological reason to do so as well, so it will make the hippies happy!! Got to like that! Reach4 mentioned the corrosion issues, so its certainly something more serious than I would expect. I like the idea of not paying $50 for some plastic and limestone tho! I am glad Reach4 mentioned it before I purchased the one in breplumb's link!
