will a crimped damage a deep well pump?
Mexico
i have a deep well submersible pump and it works great. i only turn it on to water my yard and fill my water tanks that are about 20 meters up on the top of my house. i am using 3/4 inch garden hose that i connect to another 3/4 hose going up to the tanks when i need to fill . will the pump shut itself off if the hose gets crimped? will it do any damage to the pump?
Pump could be damaged if that went on for a while. You could put in a 75 psi (common rating, inexpensive item) pressure relief valve that would release water if the hose got kinked.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
If the pump is controlled by an on/off switch and not a pressure switch, a kink in the hose would likely destroy the pump.
