What would be causing this to constantly crack?
Btz
When we slowly let the water into the tank the plumbing instantly cracks in the same place where comes into the bypass valve. The resin tank is empty. This is the second time it has cracked in the same place.
Chucky_ott
Active Member
Ontario
Are the threads for those fittings tapered? If so, I'm guessing you are over torquing the female fitting. The more torque you apply to a tapered pipe thread, the higher the stress on female fittings. As to why it's cracking when you turn on the water, I have no clue.
GReynolds929
Active Member
WA
Because it is a plastic female adapter. It should be a metal female adapter. Plastic will crack, especially if over tightened, which is very easy to do.
