Chetwynd
I need help figuring out how to configure and install my well pump/tank/booster setup.
Yes, I know I can pay someone a bunch of money to do it for me, but that's not in my nature. I figure out, eventually, how to do everything. I have more time than money. I'm not opposed to paying someone to help me or tell me how to do it.
This is a bit of a story...
House well went dry, so the current configuration is to turn on an ag pump which has a valve to fill a 1000 gallon storage tank. Out of the bottom of the storage tank the water gets pressurized using a Grundfos booster pump, which pushes it into the existing pressure tank, and on to the house. I'm not sure that there's currently any point to the pressure tank.
Original (prior to well going dry issue) configuration was 240v to the pressure tank switch, then on to the Flint & Walling control box, to the well pump. Water came out directly to the pressure tank, and on to the house.
I deepened the well, and need to ditch the ag well setup and go back to using the house well. None of this was setup by me originally, I bought the property with this all in place, recently.
Ideal setup is as follows:
1. house well pump fills storage tank.
2. when water level drops X amount, float switch tells the pump to turn on and refill it.
3. pressure tank appears to have a normal Square D 30/50 pressure switch on it, which is wired to a Flint & Walling control box as shown in the photo. A drop in pressure in the pressure tank should trigger the Grundfos booster pump to re-pressurize it.
One issue is that the booster pump is plugged directly into 120v, and is NOT triggered by a drop in pressure in the pressure tank. Power is currently OFF to the pressure tank switch.
Since my casing is only 4" now, I'm going to use a Grundfos 3" pump that I got a great deal on before I knew I was going to have a use for it. Grundfos 11 SQF 2, which runs on 30-300 VDC, or 90-240 VAC. I may end up getting a lower-cost 3-wire pump and save the Grundfos beast for future use, in which case maybe I can use the existing controller.
So, I guess what I need help with is what kind of float switch, how to wire it, whether I need a pump controller and if so is the existing one OK? I'm guessing no because the old pump is a 3 wire and the new Grundfos is 2 plus ground. Then, how do I connect the pressure tank switch to the booster pump when the booster pump has a standard 3-prong plug end on it?
I know this is a lot. You're a badass if you can help.
Thank you!
Thank you!
