I just stumbled across this forum and it looks as though some of you may have the expertise to answer a few questions.
I have a water sourced heat pump that is fed from the same well as my house water.
The setup is 1hp well pump -> PRESSURE REGULATOR -> pressure switch/gauge -> pressure tank then off to the furnace and house supply. The well is 200ft. Pretty typical setup apart from the regulator.
The regulated pressure is set to a few psi above the cut off setting of the pressure switch. The installer indicated that the regulator is required to prevent the well pump from cycling when the heat pump is on. When the water is flowing the pressure never reaches the cutoff pressure due to the regulation.
Is this a valid configuration? To me it would seem logical that at best I am consuming more energy than necessary just to create back pressure at the pump and at worst may be damaging the pump and or plumbing on the well side of the regulator.
If this is a bad configuration what should I do to remedy it?
I realise that the ideal would be seperate wells or pumps for the house water and furnace but neither of these is possible with my current configuration.
This setup has been running for 7 years now but I have noticed over the last year that the steady state pressure reading while ONLY the heat pump is on is gradually reducing. A year ago it was settling at about 47psi it is now settling at about 43psi but it also seems to fluctuate a bit with time.
Do well pumps loose the ability to pump as they wear?
Do I have a leak before the regulator? There is no air ingress so I don't think so.
Would I expect the pressure to change as the water depth in the well changes? And if so just how much would I expect the water level to vary by?
Advice or suggestions?
