I had a pin hole leak in the threads of the adapter that screws into the pitless adapter and connects to the water line to the house. I was concerned if I tried to remove this segment it would simply break off. Therefore, I used waterweld epoxy on the hole. Fixed the leak, however a few minutes later water started shooting out from behind the rubber gasket of the pitless adapter. Is it possible to stop the leak temporarily by using waterweld or a silicon sealant? Or, are there any other suggestions short of pulling the pitless adapter?
