Weird looking copper Water Softener Loop with "T" to drain line
RanDog
Phoenix, AZ
I bought a new Pulte home and wanted to put in a water softener. I identified the loop, and asked where the drain line was - they said it is the 1/2 inch line in the middle. Trouble is, it terminates in a 3/4 x 3/4 x 1/2 TEE. I don't want to open it up without understanding exactly HOW this 1/2" line terminates? Obviously, there is pressure in the loop, and with the TEE, there should also be pressure in the 1/2" line!! Doesn't make sense unless there is some sort of internal plug in the 1/2" line at some point. Thank you!!
Fitter30
Peace valley missouri
Supply to and from softener and drain line? Have a floor drain close look down the drain see if the copper is stub in there.
Check outdoors to see if there is a capped copper pipe visible. If that is a drain line for a softener, this was a bad design.
RanDog
Phoenix, AZ
There are NO floor drains, no outside stubs either. I'm betting there's something in the laundry drain area - I am not in town at the moment and cannot confirm but this is most likely.
Ask Pulte they will know for sure plus didnt you get a list of all the subs that worked there with your new owner package.
I think its to run hard water to a hose bib or fridge . But the builder or plumbing sub will tell you. when you find out tell us LOL...
