HighCountry
Hey all, I am new to this forum and have done some research on this specific issue I am having, but have not found exactly what I am looking for, in the form of an answer. I also apologize that I do not have pictures (right now), but will take some when I get home and attach to this thread for illustration. I think I can explain it well enough to get a conversation started, so I appreciate any help/advice that can be given.
What it all boils down to is this, I have a well and my well house is actually in my garage. It is a "closet" that houses my pressure switch/gauge, pressure tank, and hot water heater before entering the home. In the slab are the feeds from the well itself, to include the water pipe and wiring from the pump. These are in two separate "pipes/tubes/sleeves" (not sure the correct verbiage), but they come up through the slab next to each other adjacent to where the pressure tank and switch are located. I noticed that there was a significant amount of water (a couple gallons, estimated) coming out of this "closet" into the rest of the garage. After I wet/dry vacuumed the water out, I noticed that water was slowly (but consistently) coming out of the "pipe/tube/sleeve" that houses the wiring from the pump. The wiring is encased in flexible metal conduit, so I was not extremely alarmed at first, but it still caused some alarm. The flow at which the water is coming is very low pressure, so my initial thoughts were to just spray some expanding foam in the very narrow gap (<.25") between the "pipe/tube/sleeve" and the conduit, but the engineer in me decided that I should probably figure out the root cause and fix that, if at all possible. I did some research and am trying to figure out how water would get into that passage, and how to fix it. This is not a ground water issue, as I live in New Mexico and we are not in monsoon season, and I also think ground water leaking in is unlikely due to the fact that it is a constant pressure, but I could be mistaken. I think my next step is to go out to the well cap and see if there is any water up that high, which I believe would not be a normal scenario.
So, this is where I am hoping you fine folks can come into the equation. Is my logic sound, or have any of you had a similar problem?
Thank you for any/all help/advice you can provide.
