Let me start by explaining -- I just moved and I left my previous 10 yr old Culligan unit with the house. I am starting to miss it at my new location. I don't have all my exact numbers but can give some ballparks based on a couple guys I had out that test the water. My water is about 20-30 gpg based on some tests I've done and a couple techs I had come out and give me quotes on units. I have city water so no iron issues. Each tech recommended a 48k Unit.
I have a family of 4 (2 small kids ages 2 and 4). Based on the calculations online, 48k seems to be appropriately sized for my house. We always have someone over it seems so it might be safe to say we have 4.5 people.
So here's what I am trying to accomplish.
1) I don't want a Culligan system ($$) or Rainsoft ($$$). While they may or may not last longer, I can buy 3 Flecks online (it seems) for the cost of one Culligan. What water softener would you recommend for my situation? I have been looking at the 5600SXT but have read where it's "Old technology". I recently found on Ohio Pure Water Co. (ironically I live in Ohio) that they have the 5810XTR2. Is the 5810 the most recommended? I truly want a DIY solution. I do not want to pay a plumber to run pipe as I feel comfortable doing that.
2) My set up was going to be Line In --> Spin Down Filter ---> Triple Stage Filter --> Water Softener ---> Line Out to House. Should I do a triple stage after the water softener and just a Chlorine filter between Spin Down and Water Softener? I'll be looking at the 10% resin due to chlorine usage but wasn;t sure if I should try to filter out the chlorine prior to hitting the softener.
3) I have 3/4 inch plumbing currently in the house. If the 5810 is a 1 inch, I assume this is not an issue with going from 3/4 inch to 1 inch then back to 3/4 inch. I've read a lot on the forums and elsewhere that make me believe that this is completely fine but figured I'd throw it out there.
Thanks,
Hawkins
Thanks,
Hawkins
