Joey Hedrick
Hello all! Due to 32gpg hardness in my area, I am in desperate need of a water softener and could really use some advice in terms of placement. I have a rather narrow rectangular utility room with a door at each end. It contains my furnace, water heater, washer/dryer (front loaders, stacked), and a small free-standing shelving unit. Here is an image showing roughly how it's currently laid out, although it's not quite exactly to scale:
I get GE employee pricing and have the opportunity to get the GXSH45V at a fraction of retail, so that would obviously be my preference. The problem is, the only real spot I have for this unit would be to the left of my laundry stack (shown as a dotted line above). I would like to remove the free-standing shelves, place the softener in this spot, and mount some wire shelves up in the corner. This would give me the added benefit of opening up some space on the floor for things like my vacuum, broom, etc.
I called GE's help line and they said that the length of pipe between the water inlet and the softener should be no more than 5 feet. I have never heard of this requirement before, but I'm assuming it's to prevent a substantial loss of water pressure? In any case, due to the placement of the water inlet, which comes up out of the concrete slab foundation right in front of the water heater, the only real choice for this install would be to run the pipe back behind the water heater and laundry stack (shown with the dotted line in the image). You may be wondering why I can't just move the laundry stack over to the left to make room for it right next to the water heater -- as I mentioned, the image isn't to scale, so in reality if I move the laundry stack more than 10 inches to the left, I wouldn't be able to open that left door due to their depth.
Based on my rough measurements, putting the softener where the shelves are right now would mean a total run of approximately 8 feet, possibly as much as 9. What I'd really like to know is if this is even workable, or if GE is just being conservative in their requirements.
My other option would be to go for the Fleck 5600SXT instead. Since I can move the laundry stack a little to the left, I can make enough room for the Fleck's main tank to sit in front and slightly to the left of the water heater, and then I can put the brine tank in the left corner, running the tube to the main tank behind the washer.
Although I always had one growing up, I am a complete noob when it comes to placement and installation of water softeners. Due to the price difference, my preference is the GE unit... but I'm willing to pay the extra for the Fleck if the GE just isn't going to work. Any advice you guys can give would be fantastic!!
Thanks,
Joey
Thanks,
Joey
