JeffVee
Hi There - I’m looking for some solid advice on what my problem could be. I have a 100foot well - 20 gallon fiber woind well mate tank. I have replaced the gauge, pressure switch and repressurized the tank to 28lbs (switch is 30/50). Before swapping out the parts from above the pump would engage for about 35 seconds and then shutoff and this would repeat constantly. After swapping the new gauge and switch the cycle of cut in and cut out is about 2 minutes (2 minutes to drop from 50lbs to 30lbs- and no water was being used). At least now I know the pump is cutting in and out at the correct pressures 30/50. So I’m thinking there could be a small leak somewhere in the system - but I’m hoping someone has run across this problem and could offer some advice as to what to troubleshoot next. Thanks Jeff
