Hi, I recently replaced my water regulator after it had corroded so bad on the outside and started leaking. Everything went back together fine and got the air out of the system and cleaned all the sediment out of the faucets. I set the regulator to 60 PSI and every single faucet works great for water pressure except the kitchen sink. The kitchen sink is the closest to the front of the house where the water heater and water shut-off valve are. I took both water lines off and sprayed compressed air up through the faucet to make sure that there is no clog in it as well as i ran the water into a Bucket to make sure it had adequate pressure. There is a very strong pressure out of the water lines not connected but as soon as I put it back to the faucet I had varying results which was the same as what I've been having. I can turn on the faucet and it will be full pressure. I turn it off and turn it back on and it's half pressure. I turned it back off and on again and it's full pressure. I turn it back off and back on again and it's barely a stream coming out. I am kind of lost as to what to check next since every other faucet in the house has the same pressure is old. It seems like it's affecting the dishwasher as well since it is connected to that same water line as the sink.
Any suggestions?
Thanks
David
Any suggestions?
Thanks
David
