aceuvspades
Hello,
I have installed a new faucet and drain in my bathroom sink today and I noticed that water is pooling at the bottom of the sink. There is no waterflow issues going down the drain. The problem is the new drain that came with the faucet is plastic and sticks up a little off the sink bottom. So it does not sit flush with the bottom of the sink. Because it sits up a little there is a small amount of water that sits at the bottom of the sink and can't get over the plastic drain insert. I have to use this plastic part that came in the kit because it is a popup drain and works together with the insert.
Does anyone have suggestions as to how I can fix this? I might be able to add plumbers putty around the drain to bring the lower part of the sink up to the top of the plastic drain piece's level, although the putty will probably go out further than I would like and not look good, and I'm not sure how the putty would hold up in the long term anyway.
Or is this just something that we need to live with if we want this type of drain?
thanks
thanks
