matt wanasek
Hello, I am working on a small scale mushroom farm. I am using a sauna steam generator to heat treat my substrate. I did my first run the other nite and found that my water hardness ( around 20 gpg in this area) built up alot of loose calcium in the unit after the run was done. I am looking for the easiest and cheapest way to treat the water before it enters the unit. Are there filters that will work to remove a good amount of the calcium ? or is a softener my only option? thanks in advance for any advice.
