Wallhung boilers outside sensor
Plumber69
Prince Rupert, British Columbia
I installed a setup up with 2 wall hung boilers a low loss header and a teckmar with outside sensors. It was 2 degrees out and my primary loop was 150 and secondary loop only reached 130. It's for an small apartment with cast radiators
John Gayewski
Iowa
Your secondary pump isn't pumping enough.
To be sure your saying you only got 130 to the first radiator?
Fitter30
Peace valley missouri
What model tekmar? Usually theres 4 settings -outside shutoff temp, low temp, high temp and ratio. If i don't know the building start at 0* low,165* high, ratio 1 to 1 , shut off 68*. So at 0* 165*water at 65* 100* water. What has 2* difference? Draw a diagram how system is piped? Radiators piped reverse return?
