wall hung toilet drain tie to roof vent
wilhobbbs
Visalia, CA
I am replacing an old wall hung toilet (cracked cast iron drain unit that had roof vent) with a Toto wall hung and need to tie into the roof vent. Do you know of an aftermarket "t" that allows me to replace the Toto 90 degree drain with a "T" to tie into roof vent as per diagram below? I would run a vent pipe horizontal through 2x6 stud, vertical up the stud and then turn back 90 degree through stud to tie into existing roof vent.
it wouldnt be legal and I dont know if what you propose would fit or if a fitting is made for that. horizontal dry vent below flood level a no no . I wonder if it will wet vent through your system in a good workable if not legal way
Breplum
Licensed plumbing contractor
San Francisco Bay Area
WC vent only needs to be 2". You can do a lot once you are below the floor.
I know Geberit wall hung carriers have some different elbows to go sideways in either direction. Geberit carriers are excellent or better than Toto.
shopping
wilhobbbs
Visalia, CA
Thank you for the reply and detail
wilhobbbs
Visalia, CA
shopping
Thank you for the idea.
If that was an existing 3 inch or 4 inch vent runing up wall and out roof a 2inch vent wouldnt fly . too little info to determine that the vent can be 2 inch and not knowing the entire scope of work hard to make a suggestion perhaps aye can go on the verticle some how including below floor and banching off on 45 and then staying verticle till 6 inches above flood level? or horizontal wet vent ?
Tuttles Revenge
This may be an unpopular opinion... but toilets don't require a vent in order to function properly.
This is the code that Jeff is referring to above that prohibits that vent from branching off the drain as shown.
905.3 Vent Pipe Rise
Diagram
Unless prohibited by structural conditions, each vent shall rise vertically to a point not less than 6 inches (152 mm) above the flood-level rim of the fixture served before offsetting horizontally, ....
However, is there a structural condition that prevents you from taking a vent off vertically?
Or if we want to comply strictly to code. You could use a 3x2 Street WYE to make your vent travel vertically at a 45° angle to clear your support studs. You would install your 90 boot to the frame, transition to your DWV fitting with a fernco of appropriate sizes then adapt to your existing waste below... All very tight
wilhobbbs
Visalia, CA
Thanks for the clarification. Roof vent is 2" and existing 4" drain is in slab floor. Hoping the 4x3x4 wye will work.
wilhobbbs
Visalia, CA
Diagram
Super helpful idea. Thank you.
Correction 3x2 wye
