Vespin II water in bowl height
PatrickVespin
Santa Rosa, CA
I have 2 new Vespin II that we just had installed. One has the water in the bowl about 1/2 inch deeper than the other. The lower one has a water level about 1/2 below the first curve of the bowl (from the bottom of the bowl) and the deeper one the water is about 1/2 inch above the first curve. Curve is the first change in shape from the exit point.
The tank water height is the same on both.
After flushing the lower one fills to about 1/2 inch higher than its final level ( It fills then drains about 1/2 inch).
Variations in the casting process ??
Flummoxed in Flushville :)
WJcandee
Wise One
New York, NY
Is the lower one actually level? If the bowl is tilted backwards, the wier of the bowl is going to be lower relative to the water level, and more will drain over the weir. Otherwise, it might well be a casting issue, and you should feel free to call Toto about it. Because the bowll fills more, and then drains, I am not concerned that you might have an inadequate percentage refill, or that the refill tube is not pointing down the overflow riser, which would be two common causes of this.
I did My water level is about 5-7/8 inches below the rim. My rim is pretty level; I used a level when I placed my shims. That is below a curve. If you use a level, are the two toilets leveled the same?
Are the water levels you describe what you see after several minutes, or right after the fill?
PatrickVespin
Santa Rosa, CA
It would appear to be a "weir"D problem the lower one is a full bubble off level (front of the toilet is higher than the back).
Fantastic help here -- appreciate it a lot. Plumber will get a call tomorrow -- I expect we will need to replace the ring since we are repositioning.
Oh well -- by the way they Flush wonderfully and are a dream to keep clean !!!! (the 300e Washlet pre-rinse helps a bit I expect)
The Vespin II uses a Unifit adapter. So your plumber will not need to change the wax ring to raise the toilet with shims. The toilet has a tube that fits into the big black gasket. So when you lift the aft part of the toilet, the tube will just sit higher in the gasket.
What you will have to watch for is if the sealant/caulk under the toilet is too strong, you could lift tiles when you lift. I don't know what the procedure is to break the bond.
Then new caulk, (Terry likes Poly Seam Seal Clear usually). This is structural in that it keeps the front of the toilet from sliding.
PatrickVespin
Santa Rosa, CA
ok will talk to my plumber about this as well. Thanks .. Appreciate it
Slowly pour a cup of water into BOTH bowls then measure the height of the water. You can ONLY fill them to the design height and NEITHER one may be "full".
