ShinDiors
Was thinking putting an external sump pump outside the garage. Shortest pumping distance will be pump straight up and it will meet the gutter downspout which goes down thorough an elbow into a horizontal pipe around the back of the house, otherwise I will need 20 ft pipe on the driveway to street side. Two concerns:
1. Is the vertical pipe above the check valve always filled with water, even if when the rain stops? If it is, then freezing inside that section of pipe might be a concern.
2. Is there a way to connect this vertical pipe from pump to the downspout's discharging pipe so that the pressurized water would not block the gutter water which relies on gravity to drain down.
Thanks a lot.
Thanks a lot.
