Using Unions
BimmerRacer
Washington, DC
Is there a better way to make this type of connection? I read that some locations disallow unions behind walls, I am not certain on laws here. I also read that unions are more leak-prone.
I also read that using a reverse threaded fitting would eliminate some of these concerns, but can't seem to locate one, perhaps I am searching for a wrong thing.
unions
YOu must be anticipating problems, otherwise the tubing would be attached directly to the manifold. If unions were no allowed inside walls, there would be several million tub and shower valves, installed since the earliest days, which could not have been connected, because they ALL had union connections.
BimmerRacer
Washington, DC
I am not anticipating anything, this is a stock photo from Kohler. The servicability of the digital valve however is a potential issue.
Redwood
