Up to Code? Stub-out installed above electrical box
Opifex
Oregon
Hello. I noticed that my plumber installed a new copper stub out directly over an electrical box. I understand that building codes differ by state (I'm in Oregon), but this just struck me as a no-brainer.
What do you all think? Should I ask the plumber to fix it?
James Henry
Billings, Montana.
He could have offset the vent above the stub outs. It wouldn't have hurt anything if the drain and water stops were off center of the sink.
That's definitely a hazard. Move one or the other.
I don't think there is a problem with the pex pipes touching the electrical box. I would probably pad the screw where it might rub for mechanical reasons, or maybe I would cut that screw shorter. I am not a pro.
ImOld
Octogenerian
In the rumble seat
No code problems, no hazard, no problem there. Think of all the pipes and wires snaking through the walls of a house. Or, maybe it's better people don't see it.
James Henry
Billings, Montana.
Your correct, I was just thinking of the times I've installed point of use water heaters and how they require the water lines be attached from the bottom or side in case a leak develops.
Opifex
Oregon
Thanks all. It wasn't the touching itself that concerned me. If a leak developed at the stub out the water would likely run into the electrical box, and then who knows where from there.
