ae3799t
Not exactly a novice, but this problem has me stumped, Any help or suggestions would be greatly appreciated. Thanks
No water. Replaced Pump Pressure Switch and pump started working and we got water. Then water stopped. Noticed no pressure in system. Lifted the handle on the pump Pressure switch and pumped kicked on. Water works, then stopped again. This keeps happening.
Test:
After turning on Pressure switch, the pressure builds to 50 PSI. Turned on water and watched pressure drop to 30 PSI, then pump turned on. Turned water off and pressure built to 50 PSI again. Turned water on and again watched pressure drop to 30 PSI and pump turned on.
I do not think it is the pressure switch, unfortunately. It must be the pump or the well. Any thoughts? Thanks
One incident worth noting. On one occasion, when I lifted the Switch handle the pump came on, pressure jumped over 30 PSI on the way up and then cut out for a moment before turning back on and going to 50 PSI.
Test:
