Tub overflow problem
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by GMok, Jan 21, 2021.
  1. GMok
    GMok New Member
    Jan 21, 2021
    Colorado
    Hi guys. Probably a stupid question, but here goes.
    the tub overflow is leaking into the room below.
    Looked on YouTube and the fix seemed pretty straight forward. I got one of the gaskets that is fat on the bottom.
    problem is that the black plastic downflow pipe is flush with the tub, with no play. I took off that bracket and can’t move the pipe at all. All the vids I’ve seen show a pipe that can be moved to work that gasket around it, and it kind of sits inside the hole around the pipe a little. Do I need a different kind of gasket?
    any help on what I should do is greatly appreciated! Thanks.
Similar Threads: overflow problem
Plumbing Forum, Professional & DIY Advice Foam overflowing from toilet and cost to solve the problem Apr 11, 2021
Plumbing Forum, Professional & DIY Advice Humidifier Drain and AC Overflow Problem Feb 3, 2014
Plumbing Forum, Professional & DIY Advice Bathtub overflow plate gasket. Is this a problem? Jan 24, 2012
Plumbing Forum, Professional & DIY Advice Plumbing Problem: Primer Line Overflow Apr 4, 2010
Plumbing Forum, Professional & DIY Advice Standpipe overflow/ AAV problem Jun 28, 2009
