Weekend Handyman
Active Member
Hello:
It's me again ... I've done something dumb this time. I installed an acrylic tub without a mortar bed (I know) and it is creaking. In my defense, the directions did not call for one.
- It does creaks mostly when I am stepping into in.
- It seems to be most prominent in the middle and along the apron side.
- It does not creak when I sit on the apron.
- It does not creak when I step directly above the legs.
- My best guess is the tub is flexing when I step on a part directly supported underneath and this is causing the creaking. It feels solid and I do not see any visible deflection.
- I have access to under the tub from the back wall (i.e. opposite the apron side). It's a little tight. Maybe 1-1.5 in off the floor on the drain end and maybe 3 to 3.5 inches off on the other end.
Some background:
- It's a Maax Bosca acrylic tub (so decent quality)
- It is supported by two legs and the apron.
- The tub is on a self leveling cement pad.
- After the SLC, there was still a dip of about 1/8 under the apron. I addressed this by shims side by side to fully support the apron.
- All shim are glued to the floor with PL Premium.
Possible Solution:
- I am considering filling the tub with water and spray some low expanding foam under the tub.
- I was going to slide under a garbage bag to avoid gluing the tub to the floor.
Questions:
- Is this the best approach?
- Are there alternatives I should consider?
- Regarding spray foam, what brand / product is best for this application?
Some background:
Possible Solution:
Questions:
