Troubleshooting 2900s valve
GregJ
Florida
2900s goes through a regen. cycle and there is no water. No hard water bypass piston is in . what is the problem
ditttohead
Water systems designer, R&D
Ontario California
If you have a no hard water bypass piston, the piston shuts off the outlet during the regeneration process. Therefore you will have no water. Is it a single tank system? If so, then it is more common to use a Hard Water Bypass Piston. NHWBP pistons are usually used on multi tank systems.
GregJ
Florida
After cycle is complete the NHWBP piston goes all the way in when it should be out. My thought is a micro switch or could the top and bottom switches be out of sync. This is a single tank system,thanks
ditttohead
Ontario California
Is it a mechanical (3200) or NXT series controller? I would recommend removing the wires from the micro switches and reconnecting them. These can get installed improperly causing a poor connection. The mechanical system design is quite simple and easy to diagnose by using the wiring schematics. The electronic NXT... if the problem persists do a master reset of the controller and reprogram it.
