TOTO Neorest MS950CG Leak q’s
#Burbslut
California
my parents have a older 500 model and it has developed a leak in the fitting on the side behind a cover. It is a plastic hand tight fitting with 2 o rings and a small filter.
The whole assembly spins out. I attempted to just clean it and reinstall.
My father has lymphoma and has been having to walk up the stairs in a exhausted state so I would like to solve this sooner than later.
Can someone help? I have made a few calls around with no luck, and finding replacement parts is difficult.
I am located in Santa Cruz Ca
Thank you
Tuttles Revenge
I'm not sure if you managed to get this resolved, but I would call Toto tech support. They should be able to get you replacement parts or refer you to someone who can. That is just the filter that keeps junk out of the inner workings. Should be a part number Err.. looking up the part number and confirming it. But searching thru my manuals and product on the shelf I don't seem to have one in stock. THU911 seems to be the valve unit that the filter sits in. May need the whole valve replaced and that would entail a trained individual IMO. Good Luck.. hope you got or get it resolved!
Yugo Furst
San diego
View attachment 52258 View attachment 52259
Thank you
Were you able to resolve this? I am having the same problem and would like any information you could give.
Thanks
Tuttles Revenge
Thanks
Toto Neorest repairs for the most part can only be undertaken at one of their factory repair facilities or by a Toto trained technician who has access to Toto Neorest parts.
The leak coming from the Left side while facing the N500 is not repairable without a replacement of the solenoid valve. However, Toto has stopped servicing the N500 and the N600 as of Sept '23.
GaryK02453
Mass
Found this thread as my N500 developed slow seepage into the bowl (with annoying hissing).
Took the flushing mechanism apart, but didn't find obvious problem. Anyone knows if parts exist anywhere?
2 suspects: 1) dual-drive valves (solenoid+manual-cord turn) 2) pair of plastic pistons.
HELP!
Tuttles Revenge
HELP!
*edit* Toto no longer offers in home or factory service for the N500 or the N600.
Nobody will have access to the internal parts for any Neorest. They are all supplied from the factory to their network of authorized repair technicians.
GaryK02453
Mass
Would you have contacts for any authorized technitians who have? >>toto USA>>: "Unfortunately there are no parts available any longer".
Tuttles Revenge
Sorry I don't.
But if you go to the Toto.com website and click on <Products> <Neorest> <LS or any neorest> a list of showrooms will be displayed on "where to buy".. If any of them are plumbing shops that also service neorest then they might have parts leftover.
I would still call Toto first to see if they will help you diagnose the issue and they also would likely tell you which local company does their in house repair and MIGHT sell the parts to you directly.
