Toilet Vertical Drain Rough-in
theHaas
houston
Every diagram I've found has the toilet flange draining to a closet bend before connecting to a soil stack.
I'm roughing in a 3" drain for a toilet on the 2nd floor house new construction. The Flange perfectly lines up with a 1st floor interior stud wall. Can I use a sanitary 3" 3" 2" T and drain vertically 12' to street 90 in the crawl space and then vent from same said T thru attic?
I pray you well and appreciate the assist
ryan
wwhitney
Berkeley, CA
You can use a 3x3x2 wye with the 2" as your dry vent. A dry vent needs to come off on the vertical and stay vertical until 6" above the floor rim level. Here "vertical" includes up to 45 degrees off plumb.
Cheers, Wayne
theHaas
houston
Cheers, Wayne
Cheers, Wayne
thank you Wayne...
